Interesting bit for urS/c4 owners if anyone cares. Coilover info from KW GMBH
Yes please. If you could help me build a nice set of coilovers like yours
my searching would be over. Yours look like a nice aggressive set and
probably much cheaper than KW competition department.Comment
I put threaded tubes over my existing struts. Got some bilstein b8's shortened by 25mm and revalved for 450lbs springs. Fitted 2.5in 450lbs springs with helper springs on the front. Then got some rebound adjustable gaz shocks for the back with custom pig nose springs.
At one point when i have time I'll change the topmount on the back and run 2.25 coilsprings.
Its works effectively and together with 2bennet topmounts and the apikol rear sway bar car is on rails.UrS6 Stroker + HTA3586 =
