B2, B3, B4 subframe differences?
  • 4WDrifter
    replied
    Originally posted by varia
    saves a lot of bother and if Alex made it it’ll be right!
  • varia
    replied
    and Rotaru Sorin makes 01E mount for the B3 subframe, so no spacer
  • varia
    replied
    alex sell these
    This spacer is used when installing an 01E or 0A3 6spd transmission into a car fitted with a 5spd subframe.CNC machined from HE30 aluminium.TypeII anodised to MIL-PRF-8625
  • 4WDrifter
    replied
    I’ll get something machined once I measure the size. It’s a bit in the future.
  • K Simmonds
    replied
    Originally posted by newsh
    20mm ?
    Something like that
    No wait, isn’t that for the 6 speed box in a 3B?
    Yeah, that for putting a six speed in a 3B, though I think this guys set up is the same essentially?
    20mm sounds right, I've encounter it done with lots of washers stacked on top of each other, I certainly don't recommend doing this!
    Though have a hunt around your workshop you may find something that'll do the job nicely... I know I would in my workshop, but I'm a serious hoarder with box's and box's of bits.
    It doesn't have to be anything fancy, though getting a 20mm alloy spacer machined up will cost next to nothing and look tidy.
    Just ensure that's what you require for this application.
  • 4WDrifter
    replied
    Originally posted by K Simmonds
    You need a simple spacer for the drivers side mount if I recall correctly, the dimensions must be on here somewhere.
    Thanks Kit, I’ll have a search.
    replied
    20mm ?
    Something like that
  • K Simmonds
    replied
  • 4WDrifter
    replied
    Originally posted by quattrito
    The subframe will defo fit the UR. Only note that the ABY frame has different heights for the gearbox mounts from original frame, apart from that all fits using correct bushes as you stated.
    Thanks for this, so do I need a spacer for the gearbox mounts or do the mounts need adjusted?
  • quattrito
    replied
  • 4WDrifter
    replied
    Subframe has nothing to do with the place of the wheels. 5cyl. all have equal subframes - no difference is it 10v, 20v or 20vt.
    I know this is an oldish thread but most of the knowledgeable subscribers are still around so, bearing in mind that “there are no stupid questions “, will the front subframe from a 1996 B4 S2 coupe line up and bolt into a 1988 B2 uR quattro, as long as the bolts in the bushes are the same diameter? I realise 12mm in B4 and possibly 10mm in B2. So I might need to change the bushes to get 10mm fitting hole.
  • ristokru
    replied
    You mean B3 and B4 Quattro frames? All are the same IF the car have 5cyl, 5 speed gearbox and is quattro?
  • simon20vq
    replied
    Wishbones!!??
  • M2ki
    replied
    As I already told you on facebook, subframes are the same. How could possibly some bushes size move the positsion of something. Size is not important, as the bushes are not eccentric and center is in the same place, also bolt holes are in the same place on chassis, on all cars.
    Even the part numbers are same. Use V6 or B4 quattro subframe.
    Only gearbox mount height difference.
  • ristokru
    replied
    In audiquattro forum they say that 3B and B4 looks the same subframe but some pushes are not the same size and its moves also wheels little bit outside.
