In my never ending quest to get my Brocks working as they should, I am now looking to find out if there is such a thing as adjustable rear tie-bars for the Cabrio or if the S2 ones will fit?
Car is now poly-bushed all round, running on KW variant v1, a four wheel alignment shows that the front is now sitting on neutral camber, but the rears need adjusting as they are out.
Any suggestions? camber fiddling is new to me
This is the case, you can get camber plates for the rear stub axles which is just a posh way of doing the bodge described above.
