Guys, please, do you know torque moments front subframe on coupe quattro 20V 125kW? I read somwhere 35Nm + 1/4 turn, but i think that is not enough...
Front subframe torque moments cq20v
Originally posted by Tom_ View PostGuys, please, do you know torque moments front subframe on coupe quattro 20V 125kW? I read somwhere 35Nm + 1/4 turn, but i think that is not enough...
http://12v.org/urs/FrontSuspensionTorqueValues.PDF
Originally posted by Tom_ View PostThanks lot, i have some manula and there are 35NM+ 1/4 turn, so can i trust to your information? I know, its more than mine, but i want to be sure . Thank youRS2'd 93 UrS4 5 spd sedan
I find the same numbers here... http://www.s2-audi.co.uk/tech_articl...r_subframe.htm I know, but the front and the rear are the same torque...Maybe that 90° can be another 60 Nm, isnt it?Audi Coupe Quattro 2.3 20V
Looks like you have your B3 info and you can just ignore my C4 info. I am shocked at the low torques on that diagram, even with the 90 deg turn comment.
Originally posted by Tom_ View PostI find the same numbers here... http://www.s2-audi.co.uk/tech_articl...r_subframe.htm I know, but the front and the rear are the same torque...Maybe that 90° can be another 60 Nm, isnt it?Originally posted by Tom_ View PostRS2'd 93 UrS4 5 spd sedan
