Knew I should have stayed in bed...
Started the car (ABY coupe) up this morning, and am getting a hissing sound - like air is either escaping under pressure or being pulled into a vacuum.
I suspect some pipe somewhere is split or adrift... but thoughts on which, or other suggestions very very welcome.The hissing appears to be coming from the very back of the engine bay (closest to the windscreen), somewhere centre/drivers side. It can be heard from both inside and outside the car equally loudly (with the bonnet up at any rate). Sometimes, on switching the engine off there's an air rush sound (like a dump-to-air dump valve, but not). The hissing goes away when the steering wheel is turned (hence putting this plea in the Suspension and Steering forum. It comes back when I stop turning the steering wheel (with the steering wheel in any position).
There's no warning lights, all fluid levels look fine, brakes work without any hassle, and the bomb survives 70+ pushes on the pedal before it goes solid. Drives fine, and the boost gauge tells me there's currently no boost leak(s).
Any thoughts?
Cheers,
Ck.
