Removing track control rods.
  • John.
    • 2615
    While the front subframe is off my CQ, I'm thinking I'll now get around to fitting the new adjusters and TRE's I have. Just looking for someone to confirm that the best way of doing this would be to remove them complete with the bracket that attaches to the rack, I started to slacken one of the bracket bolts as can be seen in this picture......then I started to think-wonder if this is the best way of doing this?
    Anyone have any advice?
    View from below.
    Bled/changed the clutch fluid as well, what an easy job without the subframe in the way!!
    John.
    These help?
    http://audi.7zap.com/en/rdw/audi+cou...oq/1992-141/4/
      Yes remove the bracket off the rack piston, pop the ball joints and then you can withdraw both tie rods and bracket through the hole in the inner wing
      • John.
        • 2615
        Cheers.
