Dumb *** poly-bush subframe question.
  • John.
    • 2615
    Didn't pay much attention to my old bushes before I removed them!!.....so, does the chamfer go at the bottom so the washer acts on the whole area....or not. The bit with the chamfer is also thicker than the other half of the bush so obviously makes a difference as to how close to the chassis it will sit depending on how it's fitted? Help!!
    PLEASE NOTE PICTURE UPSIDE DOWN. Thanks in advance.
  • John.
    • 2615
    Or does it go the other way so the smaller area(like that of the old bush?) is in contact with the chassis?
    I'm thinking this way as I've just offered it up with the chamfered bit to the bottom and it seems hell-of-a close to the sump.
    (just on my tod, 'tis a bit of a juggle!)
    • John.
      • 2615
      Sorted, chamfer to the top.
        Chamfer against the washer as per your first pic
        • John.
          • 2615
          .....hhmmm. Man at Powerflex say's chamfer to the top?
          • Bowie69
            • Nov 2013
            • 2675
            Ehm, the fitting instructions say as Alex says.... and as mine are fitted.
            Having it the other way the washer would do nothing but cut into the bush!
            • John.
              • 2615
              I hear you, will keep an eye on them. Didn't get fitting instructions with them, did you pay extra for them
              Is there "on line" fitting instructions......wonder why powerflex chap said other way?
              • Bowie69
                • Nov 2013
                • 2675
                Pretty sure they were in the box!
                Powerflex bloke was probably just a receptionist
                • John.
                  • 2615
                  Aye probably, I did ask him if the chamfer went to the top or the bottom so he maybe thought there's a 50% chance of being right....or wrong!
