freont strut brace
  • studley07
    • Feb 2014
    • 211
    freont strut brace
    Hi has anyone fitted a front strut brace? does it improve handling or just cause the car to become a right pig to handle with masses of understeer. Quattro is prity good. Have fitted gas billies with uprated springs, have been told about the top of the turets on some cars where they have started to split, will fitting a strut brace improve or harm????
  • LHD_Kid
    • May 2006
    • 3695
    An S2 hss a front strut brace as standard.
    Do you mean fitting a front one on the rear or fitting a front one to a non S2.
    What car is it on?
      Umm...what car to you have? I understood that *ALL* S2s and RS2s came from the factory with strut tower bars. PN 8A0805645A
      Strut Tower Bar 101: http://forums.quattroworld.com/s4s6/msgs/203351.phtml
      • gripper
        • Jun 2008
        • 1156
        V6 quattro's too
        For what this cost me so far I could have bought an S2
          If you don't have one as standard yes they do make a good improvement, as does adding a rear one and a lower front brace too. Anything you can do to stiffen up the chassis is a good thing.
          • mdz
            • Jun 2012
            • 775
            • Country: Latvia
            I've fitted one to my 80. It's cut & weld job but might have some issues with battery clearance.
            Also recommended to remove topmounts when welding otherwise you'll melt them.
            • Mcstiff
              • Oct 2004
              • 504
              I have one too
              1995 1PissedOff90sigpic1991 USDM CQ 7aT
                I've often wondered if it is worthwhile bracing across the back of the subframe also
                  Yes That's pretty much what my lower brace does. Makes a difference
                    Didn't realise you had one, any details on what you've done?
                    • andy10v
                      • 5996
                      Sold ABY-stock
