Suspension of Disbelief, Part 1.d. cont'd.
2.) Where: Along the Front Sub-Frame to A-arm Hinge-Axis.
1. Because a good deal of the car’s driving character is riding on these most heavily loaded hinges, and that their continued best operation is essential to several other better than stock, mod outcomes; this will discuss stock hinge-axis construction, operation, failure and some of its’ effects. This contends, notwithstanding that the engine and trans-axle do over-hang and heavily burden these hinges, but rather that instead, early bushing failure simply results from the production design of their installation alone, and which actually allows them to be over-loaded by over-travel; and from an entirely different direction.
2. Two of the necessary three fixed chassis points in the tripod required to suspend the massive partly spinning wheel/brake/hub assembly in a front fender-well are the bushings which form the subject hinge. Acting together, their not insignificant job includes responsibility for two-thirds of all:
a) Fixing of the wheel position in 3-dimensional space;
b) Guiding of vertical wheel travel; &
c) Transmitting loads to and from the tire’s contact patch.
Considering these critical tasks, any play along this hinge axis is, in my view, unacceptable. This argues the stock A-arm installation can be economically improved without subtracting from the original design, but by adding to it, netting benefits in all three above areas and more. Across these two hinges, the majority of all thru-puts to and from the tires (acceleration, steering, cornering and de-acceleration/braking) take place. They should therefore, be as good as any found elsewhere, yet typically even the driver’s door hinge has less play. This hinge should approach the operating properties of the ball-joint. Otherwise what is the point of a strut-pivot so precise at the apex of the A-arm, if held at the base by a hinge so loose? The mod is an attempt to elevate them towards that goal.
3. Driving the car will be more enjoyable and stay that way longer if the mod is installed when the hinge bushes are replaced. The "Stops” mod, by altering the way the original A-arm installation functions, will prevent both early bushing failure and A-arm slide-travel. That this approach, this old but up-dated idea is perhaps still valid, may be borne out by a few observations as follows:
a) Despite even all the last model changes in the 1994 re-think that begat the RS2, the original bushings remained to carry approximately 30% more torque than previously;
b) Even today, few marques have moved away from these metalastic type bushings to any of the now several alternatives. For instance, as one does not see suspension originally hinged on poly bushes on either high-production street or purpose-built race vehicles, a question might be why has neither field embraced them?
c) While polyurethane is seen in production vehicles as bump-stops, motor-mounts and anti-roll bar link bushes, it is not seen in tasks involving rotation. In fact some poly bushing sets for our A-arms contain thrust-washers (similar in location to the subject mod’s “Stop”-washers) made of a material that is not polyurethane.
I believe the above illustrates learned folk consider the OE metalastic type of bushing still to have some merit here; that the Boges in particular, at least while still relatively new during the Porsche build program, must have been deemed adequate and that complete substitution of the OE bushing with other materials and construction may not offer the benefits the Boges plus the mod do. The issue here is ours become far less capable too quickly. The “Stops” mod aims to add durability and precision to the way the A-arm is hinged to the car, preserving the “new’ in new bushings by significantly reducing their core’s loading.
4. Note below, the contrast between how well the hinge-axis bushings are aided and supported in handling these first two tasks vs. the third:
a) Primary Arc-Travel. During vertical suspension movement, they provide a small (approx. max. 20 degree) arc of rotation. For illustrative purposes this arc is less than three and a half minutes of clock-face minute-hand sweep, a small zero-friction movement. The rate of steel bushing shell rotation relative to its core is restrained by the Mac. strut main-spring and damper. These limit the speed and displacement of rotational force that would otherwise be felt by the bush cores alone and ensure they operate inside their elastic limit. This construction will with the mod, allow the bushings to function undiminished indefinitely. Factory proper bushing installation ensures the cores are at rest with full weight on wheels.
b) Cornering. New OE bushing function is also quite strong laterally (i.e. 0.7G cornering) because there is a mid-core steel tubular support to spread the load evenly, and the steel shell directly in contact surrounding the outer rubber core to contain and back it up. Any outer shell rotation serves to further tighten the rubber core, re-centering and resisting further displacement of the bushes' metal center. Also in part because there is so little movement in what is almost a pure lateral load, (average load <200lbs. lateral / bush @ 0.7G), it is working almost solely against this, the bushing’s strongest flank. This construction will also with the mod, allow the bushing to withstand lateral loads undiminished indefinitely. Bushing core is at rest laterally when the car is not cornering.
c) Torque Transfer. Whereas here (during acceleration, de-acceleration and braking) the production design of the installed A-arm (I believe only by default) allows this task, by far (just by looking at the range of possible fore/aft bush distortion) the largest task of these three, to fall to the core, where it should only see the first two loads above and in my view never need be loaded axially. The production design puts every axial (fore/aft) thru-put, including loads sized similar to cornering (i.e. 0.7G braking) onto the bushing cores alone. There is nothing deficient about the bushings, it is because the stock load-path briefly stops at the bushing cores, and alone, axial resistance is the bushings weakest flank. Without even looking further inside the bushing, any suspension whose fore/aft fixing depends on the A-arm first moving fore or aft from its design position; second, waiting for said travel to take place; and third, the A-arm then striking slide-hammer like, the chassis bracket to which it is already fastened; must be suspect. The bushing’s integrity cannot withstand the near constant fore/aft thrust and displacement without damage, they’re only rest seen briefly during thrust-reversals and vehicle coasting. Not surprisingly, they soon degrade, less able each time to restrain A-arm travel or return it to the fore/aft “on-center” position. The A-arms are then freer with each occasion, to wander where they are pushed to. Consider that with the mod installed, this third task is no longer asked of the bushing’s cores to perform.
That in the first two tasks described above, loads are moderate and carefully taken care of with continuous load-paths from tire to chassis, whereas the last is not, (note how the axial thrust load-path stops at the bushing until the A-arm moves), serves to confirm what the voids bracketing the installed A-arm already suggest; that a deletion or omission must have occurred between the drafting-table and the production-line. This could not have been a conscious engineering decision. Early and total bush failure can be the only expected result.
5. However, even earlier on and perhaps unnoticed, the sinewy response of new bushings is lost. Well before even more visually obvious failure, fatigued bushings may allow a surprisingly large fraction of an inch in also oft undetected range of fore/aft A-arm travel, where this contends there ought to be none. If like play was seen in the nearby ball-joint each of us would replace that part immediately. This argues allowing A-arm slide-travel to develop at all in the first place is the root cause of our early bush failure.
6. WRT hinge-axis failure’s effects, what follows are two perhaps less well known examples of the possible divergent down-stream effects of this failure beyond the more obvious front-end geometry changes, variation and instability.
a) Rear-Steer. This note is regarding the older cars with the reverse-framed front-style suspension; on the rear. The same slide-travel develops here and manifests as requiring corrective steering particularly during both high-speed straight-line driving; and when de-accelerating towards a corner. This occurs in part because any alignment change or variability that occurs back here tends to be magnified, due to its greater distance (and therefore a longer lever-arm) from both the center of pressure and the C of G of the vehicle. Because the mod puts a slight compressive pressure on the re-installed A-arm bushing flanges, the arms are held more steadily than stock brand new; and the back-end trails more solidly.
b) Slack-Time. Because these hinges position the hubs, front to rear A-arm slide-travel that develops here translates directly into slack in the drive-line. Briefly, (e.g. between pulling the car forward; and being pushed by the car) the hubs are effectively briefly unharnessed. This mechanical slack becomes a delay interval which must be taken-up before each and every torque thru-put (either braking or acceleration) can take place. The older cars will display this caterpillar-like behavior at all four corners. Every launch from rest, gear-shift, throttle reversal, and brake application has to re-traverse this space, the drive-line equivalent of turbo-lag, before the car is once again either shoved or slowed by the shuttling A-arms and the huge spinning gyroscopic wheel/tire/brake/hub/CV assembly traveling with it.
As previously “Lift-pause-thump, press-pause-thump.”
While slack will certainly be found elsewhere, this slack is another reason to do the mod. During these, granted brief intervals not a great deal takes place, no torque is transmitted, the wheels are in effect de-coupled, rolling slightly forward or back without the chassis, their fore/aft connection briefly absent until the A-arms again collide with the sub-frame brackets. Mostly annoying, these periods of contact-patch unloading/zero torque/re-loading aren’t likely helpful particularly when traction conditions are marginal. However, under all conditions they continue to dull the car’s response to commands by effectively putting play in your throttling, clutching and braking; and are just an embarrassingly primitive method to both propel and stop the car. Torque may be momentarily shunted elsewhere, but with the mod, need not be. Regardless, any time the hubs are 'travelling', the car is not accelerating, de-accelerating nor braking with those wheels, activities we occasionally try to hasten. This argues said drive-line slack is yet another preventable production design behavior whose elimination yields a better driving experience.
“Stops” make the going, better.
Link to George Bush Jr. era attempt at humour sure to offend someone:
http://www.audiworld.com/forums/audi.../#post18606491
