KW V1s WITH ALBERT TOP MOUNTS FITTED
  • bilko0795
    • Feb 2011
    • 1883
    Anyone have KW v1s fitted to their car with Albert's adjustable top mounts fitted and got some picky's of the conversion plse I have just bought this set up would like to see end result before i embark on doing mine.
    I have these on mine Ray, what do you want pics of?
    • bilko0795
      • Feb 2011
      • 1883
      Hi Alex
      I have just fitted the top mounts to the coilovers ready to fit but just remembered that there are top plates to keep oem shocks on the turret and there not enough thread on the coilovers to fit the plates so was wondering how they stay in place.
        You don't use the OEM retainer. Remove the 5 x bolts on the topmount and take the retainer plate off the top. That then bolts back on when you have fitted the strut assembly to the car.
          I also used some thick washers under the bearing to spread the load on the plastic spring perch
          • bilko0795
            • Feb 2011
            • 1883
            Thanks M8 now i understand
            • Albert
              • 1500
              • Country: Poland
              that is akmotorsport.net not Albert only
              If you would have any issues than let me know.
              AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
              • bilko0795
                • Feb 2011
                • 1883
                Okey dokey Albert akmotorsport message received and understood and the top mounts fit a treat, really chuffed with the service and products.
