rear bushes (UrS4) PN help.
  • hunker7
    • Mar 2014
    • 3487
    Looking at getting some bushes for the rear but some bushes come with 2 PNs and I really don't know how they differ, maybe someone can help?
    Item 11 : 4D0 511 523 A and 4D0 511 523 C
    Item 18A : 4A0 511 247 B and 4A0 511 249 (Note: 8 teeths?????)
    Ref: http://audi.7zap.com/en/rdw/audi+100...05-505010/#18A
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
  • goodall
    • Jul 2008
    • 810
    I got these bushes from febi before
    No.18 is febi 18492
    And the two bushes that fit 18a are
    09087
    And
    09086
    • hunker7
      • Mar 2014
      • 3487
      No.18 is febi 18492
      09087
      And
      09086
      Thanks mate. What do you think about quality of Febi bushes? I am still deciding between Lemforder and Febi, price difference is quite considerable.
      '93 Audi UrS4 Avant
      • goodall
        • Jul 2008
        • 810
        The bushes seemed to be as good as OE from febi, I know that searching using febi part numbers can turn the parts up very cheap online. However if I could get boge/Sachs/lemforder at reasonable money I would
        • hunker7
          • Mar 2014
          • 3487
          OK thanks. I am still contemplating getting poly bushes from AKmotorsport at some point so don't know if it's worth spending money on Lemforder if they'll be chucked in the future.
          '93 Audi UrS4 Avant
          • goodall
            • Jul 2008
            • 810
            About £30 for all those bushes on eBay, seems ideal if ultimately going with the poly bush set up
            • hunker7
              • Mar 2014
              • 3487
              Can't argue with that They'll get me through MOT and sure improve the ride
              '93 Audi UrS4 Avant
              • Pauliusb2
                • Dec 2014
                • 361
                How many of the bushes you need?i can get you febi cheaper then online
                • hunker7
                  • Mar 2014
                  • 3487
                  I am looking for Items 14A (443 505 171 F), 11 (4D0 511 523 C) and bushes for 18A (4A0 511 249 and 4A0 511 247 B).
                  '93 Audi UrS4 Avant
                  • Pauliusb2
                    • Dec 2014
                    • 361
                    443505171F is available in lemforder 20£ each or febi
                    4D0 511 523 C is available in febi 6£ each
                    4A0 511 249 is available in febi 6£ each
                    4A0 511 247 B is available in febi 6£ each.
                    all prices in. vat and free postage to uk mainland
                    • igor136
                      • Jun 2014
                      • 363
                      • Country: Croatia
                      I need 4 bushes with part number 441505203. Did you guys know where can i found them
                      1-2-4-5-3
                      • ringbearer
                        • Sep 2011
                        • 176
                        Get rid of your old rubber bushings and insert polyurethane ones that will increase stability of the car in the corner. Polyurethane subframe bushings will give your suspension possibility to hold desired geometry under the forces while the car is maneuvering on the road. Now the subframe will not shift and the car wil
                        These will do. You can find them in poly or delrin as well.
                        • igor136
                          • Jun 2014
                          • 363
                          • Country: Croatia
                          Wow, that was quick. Thanks. I'm looking for rubber bushes.
                          Like this. I do not know, whether aluminum better and why? Is than car louder?
                          1-2-4-5-3
                            441505203 does not show up as a good part number. Furthermore, I don't think that the rear subframe bushings you seek were ever available from Audi.
                            Apikol makes a set of poly bushings for the C4 rear subframe:
                            • igor136
                              • Jun 2014
                              • 363
                              • Country: Croatia
                              Thanks Dave.
                              Does anyone has experience with this? Is this some kind of hard plastic or more like silicone? I ask because I dont want lose comfort.
                              1-2-4-5-3
