Coupe front and rear subframe bushes are the same other than the internal diameter of the bolt hole.
After just checking what I purchased last year my Coupe is fitted with the black Superflex one's fitted front and rear, I rate them, much better than the solid alloy items that were on the car when I got it. While their a little firmer than the stock rubber you'd be hard pressed to notice any difference...
I would imagine the one's Albert's can supply are just as good.
Both my ABY's have M10 rear.
