Hey,
I have been chasing for a big while on fixing my bumpsteer and
Tramlining issue on my car.I had a problem on getting the camber
Within the tolerance due to improper welding strut alignment
when modding the HP2 struts with 'built-in' damper.I normally
got the camber around -1.2 on right and -1.8-1.9 on the left (front
Axle).I have done numerous things to rule out the culprit ie.tyre,
Pressure etc.finally,i decided to get the new Billy B8 and put another
Stock untouched HP2 strut back on.I still used the H&R violet as
known as the lowest spring available in the market for C4.i also
Bought the new Goodyear Asymmetric 2 255/35r18 all around.
It sits really tight under the front wheelwell since the BBS LM has
the ET+42 on the front.the inner sidewall barely touch the steering
arms.I was so surprised after a couple hundred miles on thi setup.
It eliminated all the tramlining and horribly bumpsteer issue though
I didn't have the car for wheel alignment checking.the car feels so
Much more stability and steady.i could let one hand off driving on
the left uneven road lane without any nervous on the steering wheel.
Previously i need to grab the wheel tight when driving it passing
pavement or uneven road surface which can be found on
any bangkok roads lol.From my visual checking i believe i got the
Camber readings less than -1 degree on both left and right.I did
Modding the stock camber plate and slotting the top mount and
Pulling it all the way out for least camber.I have a set of 2bennett
Camber plate laying for years regarding the nasty noisy spherical
Bearings.my next plan is we're here going to mod some tie rods end
and another lower spacer for lower control arms balljoint to retain
The stock suspension geometry to eliminate the bumpsteer issue
After lowered the car.will be posting soon.
I used the strap to make sure my strut is all the way out lol.
