Reat Strut Brace Idea
  • Dobby84
    • Feb 2011
    • 1169
    I am looking to design a rear strut brace for my 3B S2 which I assume will fit most coupes.
    I am going to take measurements tonight and start drawing up some ideas for pricing. Looking at getting it made from carbon steel to start with.
    If it is cost effective I will look at a group buy and wanted to know what people would prefer:
    Bar:
    1. A fixed bar that bolts to brackets on both strut towers
    2. A completely fixed unit (no adjustment)
    3. An adjustable bar
    4. Square or Round
    Mounting:
    1. Curved plate to either weld or bolt to strut tower
    2. Bolt directly to strut via the top nut
    I modified a universal OMP unit to work
    • VagOrBust
      • Feb 2010
      • 107
      • Home: Netherlands
      For plug and play something like the 2Bennett one would be nice I think.
      Audi service, restoration, performance upgrades, parts and more. 2Bennett is a convenient and cost effective dealer alternative for all Audi years and models. Our 25 years of total focus exclusively on Audis means we understand how to diagnose and repair your Audi like no other. Extensive breadth of diagnostic resources and knowledge, from early examples to newest Audi models. Audi diagnostic equipment as well as parts access directly with Audi USA and Germany helps ensure efficiency and accuracy.
      5 cilinder addict:
      1995 UrS6, 2.2 turbo, daily driver, EFI coilkit, custom exhaust.
      1993 S2, 2.2 turbo, ABY, long term project.
      2006 Ford Fiesta 1.4 TDCI. Because reasons.
      • Dobby84
        • Feb 2011
        • 1169
        Yeah I have seen this and have the same brace but I tried to modify the brackets but cant get them close enough with the tools I have so getting a pair made up. This is why I was thinking about designing a complete brace and getting prices to see if people would be interested.
        • John.
          • 2615
          This would wear out the top mounts I think?....anyone?
          http://www.s2forum.com/forum/showpos...&postcount=221
          Liking that^^
          • Dobby84
            • Feb 2011
            • 1169
            I was thinking about a similar one to the fixed 2Bennet one but with the bar positioned on the centreline of the top nuts. It will definitely not cost $495!!!
            My concern is that not every car is the same and whilst one strut bar may fit a car, it may not fit another.
            • Rusty
              • 18953
              I integrated the bar with my top mount design
              The rear struts don't rotate axially but will move a little when the suspension moves in and out. You could model it from the geometry and work out how much but as you're trying to remove movement, I don't think lining the suspension strut tops together is a good plan.
              I'd look at something along the lines of the mount saver inserts with a boss sticking through the tower. You'll need a revised cap to prevent the strut falling out when not under load.
              • Dobby84
                • Feb 2011
                • 1169
                Sorry Rusty, being a bit slow. Are you saying its not the best idea to mount the strut brace to the towers or directly to the top of the suspension strut?
                  Brace the chassis not the strut mount itself
                  • LHD_Kid
                    • May 2006
                    • 3695
                    I welded a front set to the rear and slightly shortened a square section front bar.
                    Still removeable if you want the useable boot space and looks perfectly OEM...
                    Liking the OMP solution though...
                    • Dobby84
                      • Feb 2011
                      • 1169
                      I did look for front brackets but could seem to find them.
                      • mcandmar
                        • Apr 2004
                        • 5118
                        Quick and easy solution http://www.s2forum.com/forum/showthr...ar+strut+brace ....i cant believe that was 12 years ago
                        91CQ20v - Gone to a new home
                        93UR-S4 - The Magic Carpet
                        94S2Bus - The Emerald Express
                        • Dobby84
                          • Feb 2011
                          • 1169
                          Had some brackets made up to use with either the OMP bar that I have or maybe a bigger custom bar.
                          Sent from my HTC One M9 using Tapatalk
                          • PRY4SNO
                            • 767
                            Good to see someone looking at producing these.
                            I've long wanted one but haven't really liked the existing designs enough to buy one.
                            Is it possible to make one that is fully functional but won't interfere with folding down the rear seats? I love the utility of the cargo space.
                            2013 Touareg TDI /// #farmenwagen
                            • Dobby84
                              • Feb 2011
                              • 1169
                              Well I am going to use an OMP brace for now that can be removed easily. I may look at designing a bigger brace in the near future using the sme ides as the OMP one.
