Just stripped out - to swap over for FARB sway bar fitting - my rear struts and wondered if the gas insert cap and the rubber boot and foam bump stop are still available to buy ? Metal cap was seized on but have managed to grind a cut in it and remove and plug weld up cut and grind so salvaged , but got other side to do and may not be so lucky that side ! Ta..
