KW suspension question
  • snp10
    • Nov 2012
    • 189
    • Country: Romania
    On the kwsuspension website there are 2 versions of V1 suspension kit for s2. The difference is the Axle load FA/RA . One has axle load FA/RA:951-1100/- 950 and the other Axle load FA/RA:- 950/- 950 . What is the difference and what I must purchase?
    Welcome to KW suspensions! With us you will find a suspension solution for every use ➤ Whether road, trackday or professional motorsport!
    Thank you very much.
  • rxl
    • 1913
    aby has 1100/950
    • Monkeymagic
      • Mar 2012
      • 3419
      Axle weights are on your vin plate on bulk head
      • pasbogdan
        • Sep 2009
        • 1160
        • Country: Romania
        Good to know,but the car is other thing compared to what was from factory..
        • snp10
          • Nov 2012
          • 189
          • Country: Romania
          Ok, but KW gave two solutions for Aby with different axle load. 950-1100/950 and 950/950. What is the difference?
          My car is original a coupe quattro 2.8 v6 with 2.2 conversion.
          • rxl
            • 1913
            the easy way would be to ask kw suspensions directly.
            more load will not harm..
            • mac2226
              • Jun 2008
              • 1289
              I went for high load version but mines are v3 for aircon car slightly stiffer springs I believe
              • 1781cc
                • Nov 2011
                • 1253
                Make sure you get the right M bolt variant as well, my lower mounting points were M12 not the M10 option (not sure if the S2 changes, but the cabs have two different bolt options)
                • rxl
                  • 1913
                  Coupe s2 have m12 or m14 bolts.
                  Gesendet von meinem GT-I9505 mit Tapatalk
                  • taren86
                    • Nov 2013
                    • 40
                    • Home: Estonia Current: United Kingdom
                    n my original audi s2 log book is written up to 1000kg (front) and up to 950 (back). So I have just bought kw v1 1000-950kg with m14.
