Any Power Steering Pump geniuses out there?
  • Grillage
    • Apr 2012
    • 156
    I'm having problems with power steering in my ABH v8 swapped coupe and I wanted to ask a question...
    I have a groan that will not go away despite replacing the rack and pump. I have an ABH steering pump modified to disable the brake bomb line by removal of the little cylinders that drive it.
    Now I realize that it could be an issue of too much pressure to the rack from the pump.
    The coupe and cabriolet racks are 100 bar and the v8 pump is 150 bar.
    I asked on my motorgeek thread whether the removal of pistons could help solve this and user "elaw" responded in the negative explaining:
    The way that 99% of hydraulic power steering systems work is that the actual pumping mechanism (the vanes) creates a variable flow that depends on engine RPM, and there's a special valve on the outlet that regulates flow by bypassing fluid back to the pump inlet, and can also limit pressure the same way. So the output of the pump is a constant flow with a pressure limit - it's done that way because the way the steering assist responds is related to the flow, and you don't want that to vary with engine RPM.
    The way the rack works is that under no load (when no assist is being called for), the fluid just flows through the valve body (in the rack) so the pressure in the system is almost zero. When you turn the wheel and assist is required, orifices in the valve body start to close, causing pressure to build. That pressure acts on the piston in the rack to assist the steering. So the pressure basically is proportional to the force you're putting on the steering wheel, up to the limit set by the valve in the pump. That's why normally the pump is pretty quiet, but gets noisier as you apply force to the steering wheel - it's because the pump is being called on to produce more pressure.
    So the bottom line is 1) the pump pressure really doesn't mean anything except when a lot of force is being applied to the wheel because the pressure spec is only the limit and it's only reached when a lot of force is applied to the steering wheel. And 2) if the flow needs changing (which may be what's causing the whining), the only correct way to do it is to recalibrate the valve on the pump outlet.
    So to apply to my pump (I have a couple spares including one that's frozen that I disassembled):
    [/url]
    #1 - Supply of Pentosin to pump
    #2 - three sets of pistons that feed the steering rack
    #3 - one set of pistons that feed the brake bomb (these are smaller diameter pistons)
    #4 - outlet to the rack
    #5 - outlet to the brake bomb
    I have disabled the brake bomb section by removing those smaller pistons, rods and springs
    Here it is just cracked open (this one is a bad pump I got from Force5 with all the pistons frozen in it)
    A - These are fed from the three sets of pistons (#2 above)
    B - These line up with A and appear to have one way valves letting pentosin through from A but not backward
    C - This (I believe) is the pressure relief valve that sends fluid back to E where it can pump back through the pistons and A
    D - this is the little crankshaft that hits each pistpn
    E - This flows back into the piston system
    I pulled C out from above...
    It looks like this:
    So in theory, a different relief valve could change this pump from 150 bar to 100 bar?
    I took that piece apart to try and figure out how to do so...
    It's got a tube with a spring around it on the "return to pistons" end, then a collection of ball bearings that would push against it with a screen ahead of them...
    tube / Spring:
    Ball Bearings and screen:
    So in theory, as pressure builds in the rack (due to not needing flow), the pressure builds in the fat end of the pump.
    When that pressure is high enough to push the bearings into the spring and push the tube opening bigger, there is flow back to the pistons.
    This would be what sets the pressure of the pump.
    So I wonder if a lighter spring would reduce it?
    Anyone have experience with this?
    1994 Cabriolet - 5 speed
    1995 90
    2011 A4 Avant
    1990 CQ - V8 (sold)
  • andy10v
    • 5996
    Is it groaning all the time?
    Is there not a power steering hose people often replace with a normal hose and it makes noises as the OEM one has something in it?
    Sold ABY-stock
      That is the pressure relief valve you've disassembled - they are quite sensitive to the spring preload so you might be best replacing that now.
      The relief valve opens when you are at the lock limit, it hasn't got an effect on the line pressure. The amount of flow the pump can output affects the line pressure.
      The flow limiting valve is basically specific size orofice, normally fitted in the pump outlet.
      I've never had one of these type of pumps apart, so not familiar with them.
      In the older style pumps the flow limiting valve is a press fit brass piece in the back part of the housing, none of your pics show the outlet housing very well so can't see it.
      HTH
        How our power steering and brake pump works
        How our power steering and brake pump works:
        Contains this pump rebuild pdf:
        • Grillage
          • Apr 2012
          • 156
          The S4/S6 pumps are Vane pumps but have a single piston activated output to the brake bomb. The V8 pump has the same piston activated output to the bomb but also a three piston output to the rack.
          My initial thought was that disabling one of the three sets of pistons would reduce the pressure. is that crazy?
          1995 90
          2011 A4 Avant
          1990 CQ - V8 (sold)
          • diesel des
            • 3896
            Would reduce maximum flow but not really affect pressure other than being less smooth I would guess.
              I presume the pressure that the pump makes for the brakes cannot be increased to give more assistance for the oem brakes, to avoid chasing the advantage of more powerful assistance by changing to vacuum servo assistance ?
              Sorry for the slight thread hi-jack, but sort of related.
              Thanks.
              • diesel des
                • 3896
                Thanks.
                My experience is that vacume servos are less powerful than the oil setup....
                • Grillage
                  • Apr 2012
                  • 156
                  This is a writeup on a GM pump but seems to confirm my theory on the spring dictating pressure. They're using shims to beef up the spring to increase pressure...
                  1995 90
                  2011 A4 Avant
                  1990 CQ - V8 (sold)
                    If you want to reduce the line pressure, you need to reduce the size of the outlet orifice.
                    Another option you can use but it's a bit messy is to insert a flow bleed-off valve inline to the rack, with a return to the reservoir. The balance is very, very fine.
                    • Grillage
                      • Apr 2012
                      • 156
                      After all this, I had a second hose made today. The original one was made by a recommended vendor across the country from me (Spokane House of Hose) and they knew to include the restrictor etc. I was screwing around with the hose while it was out of the car yesterday and I realized that the opening seemed like it might be too large. I started questioning whether there was a restrictor in there at all after I was able to run a 10AWG wire through the hose without problems.
                      So I figured I'd take the hose I pulled from an A4 the other day and modify the end to fit. Found a local hydraulic shop and had it altered to fit my setup.
                      Installed it today and the noise is definitely better. The steering still feels a little tight but the noise is pretty much gone. It's much nicer to drive at lower speeds now.
                      I'm thinking I'll leave well enough alone for now.
                      1995 90
                      2011 A4 Avant
                      1990 CQ - V8 (sold)
                        Good result. You probably screwed your pressure relief valve though
                        • Grillage
                          • Apr 2012
                          • 156
                          I have three of these pumps now. I thought that the one that came from my 93 (V8 with the ABH engine) was bad due to these symptoms originally so I ordered another from Force5 in the US. The first replacement was totally frozen up so they ended up sending another replacement.
                          I took apart the one that was shot - no harm done to either of the good ones.
                          1995 90
                          2011 A4 Avant
                          1990 CQ - V8 (sold)
                            • cuatrokoop
                              • 12
                              Dredging this back up...I used to own several Type44 cars (5k, 5kq, 5ktq, V8q), so naturally I have repair manuals for them. The manuals have complete breakdowns of the ZF pumps. If you need to run one of these 2+6 piston pumps (2-pistons for brakes, 6-pistons for steering) on a B3/B4 vehicle, you will need to use a different pressure relief valve to change the pressure setting from 150 bar to 100 bar (gleaning this from reading the testing & troubleshooting section of the Bentley manual).
                              http://coupe.gofergusons.org
