Steering "slop"
  • Beetie
    • Oct 2003
    • 1517
    My mate had this problem on his cq20v, and his was something to do with adjusting something. Not quite sure what tho. Ill txt him and get him to post....
    Was a '93 3B, Dont ask now tho......
    • pastures16
      • 2058
      ive got the same problem steering feels loose jumps left to right over small bumps it floats i changed top mounts subframe bushes wishbone bushes anti roll bar bushes sill the same found 2/3mm play in the tie rods (rack end) that tightend it up a bit but its still not right going for new shock inserts this weekend let us know how you get on ill do the same
      94 s2 avant
      aoc member 1116
      • pastures16
        • 2058
        isnt there an adjuster for the rack its in the o/s wheel arch
        94 s2 avant
        aoc member 1116
        • dan_b
          • Sep 2003
          • 3670
          The car's going back tomorrow (Saturday) so we'll see what's what...
          • s2driveruk
            • 12696
            yeah there is a bolt on the rack just below the brake fluid reservoir, carefull not to overtighten though otherwise your wheel won't self centre again, BTDT
            David
            1992 3b S2 Coupe
            • dan_b
              • Sep 2003
              • 3670
              #21
              Would they have had to have gone near the rack to have done the top mounts?
              • Stick Insect
                • Dec 2003
                • 2338
                The tie rods would have had to be undone to drop the legs IIRC.
                I like Porkkis' suggestion, bad to in ( or out) can have this affect the steering wheel seems to have a mind of it's own.
                I went to my local Ford Rapid fit and had the 4x4 Mondeo suspension aligned last Friday and it is now wonderful again ( as well as a Ford can be!)
                Get the suspension properly 4 wheel alighned, your local Ford Rapid fit should be bale to do it. Ask for the measurements before and after.
                I took some Mars bars in and it only cost me £20..
                P.S. make sure they have the correct suspension alignment settings, theirs may be wrong
                • dan_b
                  • Sep 2003
                  • 3670
                  #23
                  What are the correct suspension alignments?
                  I'm hoping they'll look at the car tomorrow - bearing in mind that this aspect of the car was fine before they did the work, should I be able to get this done for free?
                  • Mikes2
                    • 1704
                    The tie rod ends may have been damaged during removal. This is very easily done as they can be stubborn.
                    Mike
                    http://www.s2-audi.co.uk
                    • dan_b
                      • Sep 2003
                      • 3670
                      #25
                      Hmm. Surely they should have picked this slop up in a test drive? They actually drove my car back to my house! Gah. I guess I'll find out tomorrow...
                      • dan_b
                        • Sep 2003
                        • 3670
                        #26
                        Ok. 2 new left wishbone bushes, 2 new gearbox bushes and 2 new rear diff bushes later and the car is absoloutely brilliant. Steering slop has gone, bump-steer is reduced significantly: transmission shunt is reduced dramatically and the rear diff thumps a bit less too. Ride has firmed up a little bit, but I don't mind that.
                        The steering responsiveness now is really rather impressive: with the uprated ARBS and the H&R/Konis, boy does this turn in quick and stick like a limpet
                        • Fat Audi 80
                          • 10547
                          Glad to hear that you got it all sorted out. They are lovely cars when they are "right"...
                          Cheers,
                          Steve
                          The Perfectionist
                          • dan_b
                            • Sep 2003
                            • 3670
                            #28
                            Lovely, but whoppingly expensive
                              How much did that little lot set you back? did you go for the powerflex bushes on the wishbones and rear diff?
                              • dan_b
                                • Sep 2003
                                • 3670
                                #30
                                I went with standard bushes on everything. Having put the Powerflex bush on the rear diff rear mount last year and subsequently getting very much increased transmission vibration, I didn't want to get any more of that, or make the ride significantly firmer than it is already with the H&Rs!
                                The 6 bushes set me back just shy of £100 in parts. I didn't have the facilities to do the fitting myself, paid for 4 hours of garage labour.
                                Anyone who has 14-year old rubber bushes on their car should consider replacing them, especially if you're looking to upgrade any other part of the suspension!
