Running gear hard wear
  • jsws3
    • Apr 2012
    • 1174
    Has anybody got a full list of nuts / bolts / washers ect ect to replace all for the s2 running gear ?
    As I'm going to convert the ur's running gear to s2 and would like to buy them all new before I pull the car apart .
    Originally posted by jsws3
    Has anybody got a full list of nuts / bolts / washers ect ect to replace all for the s2 running gear ? As I'm going to convert the ur's running gear to s2 and would like to buy them all new before I pull the car apart .
    Seems like a big ask but you never know.
    For the C4 UrSs, Sean D. (quattro20V) on my home forum, quattroworld UrS, compiled a C4 list:
    http://12v.org/urs/suspension.pdf for his suspension rebuild, as documented http://forums.quattroworld.com/s4s6/msgs/40891.phtml
    Maybe somebody did that for a B3 or CQ (??)
    At worst, you can do it yourself with:
    http://audi.7zap.com/en/rdw/audi+cou...acoq/1992-141/
    Good luck
      Funny you should ask - I have started to build up such lists for my C4 and B6 wagons - they share a lot of common nuts and bolts at the front so I have made up a couple of ziplock bags of fixings... I hate it when you source parts in a hurry for an unplanned repair (e.g an exploded air-spring) then get held up chasing TPS for some stupid general nut or bolt.
      Would be a good idea for the S2 - both as a list of Audi part numbers and general / aftermarket alternatives.
      • AndyP
        • 6049
        Front
        Subframe bolts : 3B M10 : M10x75mm N 905 569 02
        ABY M12 : M12x85mm N 905 808 01
        Wishbone bolts : M10x75mm N 905 569 02
        Bottom ball joint pinch bolt : M10x45mm N 010 445 7
        Bottom ball joint mounting nuts : M10 shouldered nut N 902 856 02
        Strut to hub bolts : 3B M12x1.5x76mm N 102 065 01
        ABY M14x1.5x76mm N 906 244 01
        Anti roll bar clamp bolts : M8x18mm N 101 016 03
        Gearbox mount to subframe : M8x20mm N 010 240 16
        CV joint to gearbox : M8x48mm 893 407 237
        Rear
        Wishbone bolts : M10x78mm N 904 893 01
        ABY M14 M14x1.5x76mm N 906 244 01
        Rear tie rod mounting bolt : M12x1.5x50mm N 010 142 7
        Rear Diff mount to subframe : M8x20mm N 010 240 22
        CV joint to rear diff : M10x48mm N 900 972 02
        A lot of these are NLA from Audi, suprise suprise, so if your going to get them from a nut and bolt supplier make sure they are high tensile, the strut to hub bolts and subframe bolts need to be grade 10.9 minimum, with grade 10 nuts.
        If I've missed anything, let me know and I'll add it on.
        • jsws3
          • Apr 2012
          • 1174
          Cv joint bolts that bolt to the flange on the box and diff please
          Ps thank you for sorting this list mate your a 💎
          • AndyP
            • 6049
            Updated
