Hello!
I'm having problems with my power steering.
I've done:
* Engine swap from 2.8 V6 to 2.3 20v
* Replaced the tandem pump with the V6 pump
* New steering rack
So, if I turn my wheels to the left, the pump starts spinning by itself. If I turn wheels to the right, pump is staying still. That means if I tighten the belt, I can only turn wheels to the right. Starting the engine will make the steering rack move by itself, though it hasn't any air inside. Also I don't have any valves inside the banjo bolts.
Exactly like this ^
What should I do?
I've done:
* New steering rack
Exactly like this ^
What should I do?
Connect them the other way around.
