i like the Audi Sport Quatro S1 Replica Wishbones but they are very expensive and i wonder if the car drives better on road or track with this wishbones?
is the cost worth it ?
have they the same triangle points as origional coupe quattro wishbones or or the ball joints moved to a other possition?
Audi Sport Quattro S1 replica wishbones / control arms for front and rear axle. With high attention to detail, this is the best and most precise replica wishbones available. For quattro cars that need unchanged geometry in every road, gravel and track conditions as stock wishbones pressed and steel tend to bend if used
TWINCHARGED power,zero lag
AEM W/M injection
We make and sell them so basically:
- they are stronger then oem ones. do not bent in corners
- enable setting desired caster setting
- add camber to cars geometry
All of the above account for getting faster through a corner
