So.. Can it be done?
I'm now considering having the front standard AEL QUATTRO struts converted to coilovers with a sleeve.
Has anyone done this to the standard suspension before?
Are the needed parts available? & what would be needed for the top perch?
Anyway of using the standard top mounts?
Trying to keep cost down as much as possible, so will also want to keep the original dampers.
As for springs, id like close to original ride quality maybe a 'little' firmer.. & also want to run at about the same ride height as stock AEL quattro. (so a little lower than FWD models)
