Electric steering pump
  • V6quattro
    • Sep 2008
    • 949
    Originally posted by quattro-nick
    i believe "v6quattro" here on the forum have had a powersteeringpump from a mr2 on his car
    he has now converted to an elektric steeringcolum from a opel carsa
    I only have experience with the old style mr2 pump withs wasn't very powerful when parking and made lots of noise. I suggest to use a pump from the mk3 mr2
    • jsws3
      • Apr 2012
      • 1174
      What's the benefits over stock set up
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        for me,i just needed the room on the engine for my supercharger
        TWINCHARGED power,zero lag
        AEM W/M injection
        • Thuppu
          • 4115
          What about converting to fully electrical, no need for any hydraulics..?
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            #20
            it's doable,i've seen someone using an elektric steering column from a opel corsa
            AEM W/M injection
            • Thuppu
              • 4115
              Yes, I have that in my B4 but I havn't yet been able to test it.
              • Kiku
                • Aug 2010
                • 497
                Fully electrical isn't the way i would like to go right now since i had full renovation done with steeringrack. Anyways V6quattro you mentioned that you have old style pump, mk1 or mk2?
                And if i understand correctly then mk3 pump with own reservour is more instalatsion frendly since the original audi reservour is quite bad location when using the new electrical pump right? Or is there any other particular reason?
                • V6quattro
                  • Sep 2008
                  • 949
                  I used the MK2 pump mounted below the rear seat.
                  • Kiku
                    • Aug 2010
                    • 497
                    By making sound you mean whining i guess? Actualy the original pump i have right now makes also noise and i realy need the space under the hood. I think i will try it out and see how good/bad the idea is. Power supply is one from alternator and one from battery and then ground?
                    PS: what oil do you use in electronic pump? ATF? Toyota special? How does the original rack function when not using original green mineral fluid. Specialy when you already have driven with the original fluid for a while.
