Subframe bolts.
  • John.
    • 2615
    Subframe bolts.
    My CQ has poly bushes between subframe and chassis, I'm looking to replace the bolts as I never did when fitting the subframe.......just used the old ones.(m10 x 80 ish)
    So I was looking on line and then checked here.... http://www.s2forum.com/forum/showthread.php?t=26873
    .....and now my head's numb!! Is it best to use bolts supplied by power flex or just replace with OE spec?
    ....then I saw these....... http://www.ebay.co.uk/itm/Genuine-Vo...0AAOSw8oFXzXnd ??
    Cheers.
    John.
  • mac2226
    • Jun 2008
    • 1289
    Use oem bolts
    • John.
      • 2615
      Originally posted by mac2226
      Use oem bolts
      Couldn't find a part number in the post I linked above......just the torque setting?
      Do you know part number?
      • andy10v
        • 5996
        5 N 90556902 hexagon bolt F >> 8B-N-015 000 M10X75
        (5) N 90580801 hexagon bolt F 8B-P-000 001>> M12X1,50X85
        Sold ABY-stock
        • nribs
          • Aug 2015
          • 91
          https://store.034motorsport.com/mqb-...s3-tt-tts.html
          Pricey
          • John.
            • 2615
            Thanks Andy.
            • Mikes2
              • 1704
              Those 034 bolts are stainless steel. Completely not suitable for this application
              Mike
              http://www.s2-audi.co.uk
              • John.
                • 2615
                Originally posted by Mikes2
                https://www.vwheritage.com/n90556902...mission-mounts
                The bolts are OE Mike according to the script?.......Thanks for the link, I'll order these I think, price is reasonable I think?
                • Mikes2
                  • 1704
                  The VW Heritage ones are the right ones. A bit pricey but not much option these days. Pretty sure they're nla via Audi dealers / TPS.
                  You'll need 8 of these for each end so it starts to add up
                  Mike
                  • John.
                    • 2615
                    That'd sound about right !!
                    • AndyP
                      • 6049
                      £4.50 for one bolt
                      http://www.ebay.co.uk/itm/M10-x-1-5-...HtJeG5nu3tDQFw
                      • John.
                        • 2615
                        Originally posted by AndyP
                        Would this type be better?
                        • Colesy
                          • Feb 2009
                          • 2981
                          I don't know much about bolts but the subframe bolts are supposed to be stretch bolts aren't they? So probably best to stick to ones the right spec.
                          • Mikes2
                            • 1704
                            In the fitting application for the subframe 35 Nm + 90 degrees is not going to stretch an M10 8.8 bolt
                            Mike
                            • AndyP
                              • 6049
                              OEM bolts are 10.9 as in the link I posted, I'm sure this is the seller I got mine from
