Guys
i have an usr6 1995 , aan with a 01e
nowadays the car has a set of bilstein b8 and h&r 29800 springs
i dont have any kind of weight reducion. i use the car to travel with my family so even the a/c is blowing cold air.
the car is pushing +- 400 awhp . it run on vems and e85.i dont need more power because on some curves the car smoke the tires on aceleration because poor weight distribution + the lateral g
for the street, the car is perfect.
for the track, i feel i need more spring power on the front
check those pictures how´s the front in diving and the rear is in the air.
I am not even using good tires. just some crap street tires that went thru 3 track days already.
i don´t wanna use kw because of costs and the actual difficulty to find it here in brazil
i was thinking on using h&r race springs, 29771 , but as i researched, those springs are for the s6 plus with a v8 engine and possibly with auto trans. much heavier than my aan with 01e..
so i guess i will have height problems between the front and the rear.
eibach are supposed to be softer then h&r
any one has any comments on this?
apikol rear sway bar? i dont see the apikol fixing the dive issue. it can help the balance on the curves but not the dive itself
i need to brake from 240 to 120/130 in 100 meters and it sucks doing so with the rear end dancing
