How AK Top Mounts + KW v1 coilovers install
  • M_GORDON
    • Oct 2008
    • 1295
    • Home: Isle of Man Current: Vatican City State
    Hi friends!
    Some month ago, I bought and install with my mecha friend on his workshop some KW v1 coilovers and a pair of AK Motorsport Top Mount.
    My friend told me how that we must mount but I'm in doubt.
    The top mounts are like those:
    And here some pics
    I think it's wrong I can heard some "clock" en the right side. And fronde the motorbay I can see a few of coilover inside teh TopMount.
    Maybe I leave the tread? but... how install the spring cover?
    THANKS A LOT GUYS!
    photobucket SUCKS
  • PeterS
    • 423
    Looks like you still have the bearing from the old OEM style mount on that strut...
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
    • varia
      • 821
      • Current: United States
      indeed Mr. is right, no need for that bearing
      • blux
        • Feb 2017
        • 237
        • Country: Belgium
        Yes. Your KW end where the purple plastic is. Is the bearing stuck on your coilover?
        1967 fiat 500 future project
        1976 audi 100 coupe S
        1989 vw corrado 16V
        1989 audi 90 quattro 20V sport
        1994 audi RS2 project
        1994 audi RS2 parts car
        1995 audi RS2 project
        • A1QSHIP
          • Aug 2004
          • 975
          Looks like the stock spacer nut is used to hold the bearing in place. I'd love to see a picture of the AK Motorsports fastener that holds the topmount to the strut.
          "Nulla tenaci invia est via"
          • andy10v
            • 5996
            Picture stolen from rxl
            Originally posted by rxl
            Sold ABY-stock
            • M_GORDON
              • Oct 2008
              • 1295
              yes...
              And w/o the nut or the bearing or the tread; I don't know how hold the purple top from the KW; and assemble the Top Mounts
              photobucket SUCKS
              • jade
                • Jan 2005
                • 1811
                Originally posted by M_GORDON
                yes...
                Spring compressor ? or possible you could line it up and use a Jax to compress it into place.... it you have the adjuster backed off it should not be difficult
                RS 2 580HP
                • PeterS
                  • 423
                  I believe the process is:
                  dis-assemble the top mount, separate top and bottom pieces, compress spring, put lower half of mount (with the spherical bearing) onto the strut, install the strut nut, decompress spring, install strut assembly with lower mount into wheel well, put the upper mount onto of the strut tower and fasten to the strut assembly/lower mount and tighten the 6 M6 bolts per AK Motorsports web page: " Notice: The top six M6 screws should be tightened using Locktite 243 at 10 Nm."
                  Two piece top mount with 12 mm offset made from PA9 Aluminum produced on C.N.C. machinery. It is the biggest offset available on the market ! Can be used to set maximum camber/caster without cutting the cars body. Includes Fluro (German) precision 35mm race bearing secured with an steel locking ring. Bearing is mainten
                  Peter S
                  1991 Coupe Quattro
                  1991 Coupe Quattro
                  1995 S6 Sedan
                  1995 S6 Wagon
                  • M_GORDON
                    • Oct 2008
                    • 1295
                    https://www.akmotorsport.net/shop/al...h-12mm-offset/
                    I think it's true correct method! THANKS A LOT!!
                    PS. other opinion or the real true process?
                    On AK Motorsport they didn't say me anything
                    photobucket SUCKS
                    • Albert
                      • 1500
                      • Country: Poland
                      M_GORDON > please let me know if you need any help with TM.
                      AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
                      • M_GORDON
                        • Oct 2008
                        • 1295
                        Hi Albert
                        Some month ago I ask U and (I think why extrajob) you only send me a link to the page where I can buy them; but where we can't see how install properly.
                        Thanks if you can write the method to install them.
                        chears!
                        photobucket SUCKS
                        • Albert
                          • 1500
                          • Country: Poland
                          Its maybe me because I am a technician but the steps are very easy. If it seams complicated please visit a mechanic workshop to do the job
                          1. take out your struts and OEM top mounts
                          2. put the washer on the top of the struts
                          3. but the bigger top mount part on the top of the struts
                          4. slide it through the metal slot. pic
                          5. Use two tools to thigh-en the shock to the top mount. The top screw should be the yellow screw provided in the set (here is silver on the pic). Use 85 Nm.
                          6. put top part of the top mounts and the top six M6 screws should be tightened using Locktite 243 at 10 Nm.
                          7. you are done
                          • Albert
                            • 1500
                            • Country: Poland
                            one addition. You remove the nut form the KW and put the washer in the same place, on top bearing with top mount and on top screw. Pics bellow
                            • M_GORDON
                              • Oct 2008
                              • 1295
                              HI!
                              Yesterday I went to the workshop to disassemble everything and assemble as you indicated.
                              And yes, it's very easy and looks perfectly. I don't know what my mechanic would be thinking about that day.
                              The problem is that I don't find the washer that was embedded in the bearing. Is very important?
                              Sure my mechanic lost it.
                              photobucket SUCKS
