squeaking noise
  • stevieyid
    • Apr 2005
    • 2251
    squeaking noise
    hi, when at high speeds around 90-100 i get a sort of squeaking noise coming from somwhere. Anybody got any ideas what this could be
    3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
  • alg
    • Apr 2004
    • 1160
    mouse stuck in inlet manifold.........................?
    Sorry could not resist Can you provide more details
    Alastair
    RS2
    • s2carlo
      • 252
      BTDT, It's the lock of the trunk.
      Put some grease or vasalin on it.
      No power, no glory!
      S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
      • alg
        • Apr 2004
        • 1160
        Coupe or avant
        Rear tailgate on coupe well known for these noises. Also consider
        1 Seatbelt adjusters
        2 steering wheel column plastic cover
        3 front dashtop air vent usually more a rattle
        4 rear seats if leather
        Best idea is to get someone to sit in the back and passenger seat to try to locate
        Good luck
        Alastair
        RS2
        • blu_s2
          • 392
          no clues, part of the fun of owning an S2, tracking down all the squeaks, ticks and clonks!
          Jim
          • s2driveruk
            • 12696
            my car squeaked when the drop links at the back were worn out, changed and solved
            1992 3b S2 Coupe
            • stevieyid
              • Apr 2005
              • 2251
              You cant hear the squeak with the window up but if u open it you hear the squeaking. Could it still be these suggestions?
              • Ski
                • 2591
                Hi Guys.
                The squeaking situation is getting out of hand, and I need some sort of a De-Squeaker spray (silicone i think).
                Will haford supply such a spray?
                ABY Coupe
                • richslay
                  • 153
                  Not sure about halfords bu Maplin will. Also worth bearing in mind that VAG Parts do an anti rattle felt strip code ARFS
                  • Jeffer
                    • 2057
                    Check brake dust covers on wheel hubs. Mine touched a couple of times and make horrible noises. Good luck with tracking down the squeeks. The S2's is a piece of cr@p if it concerns squeeks. They really annoy me
                    Probably got to do with the structural integrety, or something like that.....
                    RS2 Black - stock 315 HP
                    RS2 RS blau - stock 315 HP
                    Sport Quattro - 1005 HP
                    High Octane website
                    • Ski
                      • 2591
                      Its to do with no frames around the windows i think.
                      anyway, its internal squeek, sounds like rear seats / passenger seat.
                      ABY Coupe
