90 20v quattro hubs?
  • Dave cook
    • 312
    hi, does anyone know if a S2 front & rear 5x112 hubs would fit a 90 20v quattro
    cheers
  • Stick Insect
    • Dec 2003
    • 2338
    I am half way through fitting them to my coupe quattro 20V and they have gone straight in.
    HTH
    David
      Lots of N.Am 'eS2' folk have proven this true already.
      Paul
      • mcandmar
        • Apr 2004
        • 5118
        David, Are the rotors the same diameter as the S2 ones or are they bigger? Are the calipers the same?
        Thanks,
        Mark.
        HTH
        David
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • Dave cook
          • 312
          the 90 20v quattro runs 276x25x51 front discs the S2 276x25x56
          i think i need to just bite bullet and try it
          • 90quattrocoupe
            • Nov 2003
            • 771
            Thanks,
            Mark.
            Hi Mark,
            Not David, but I completed mine a while back. Discs are the same size and brakes the same if your car came with the G60 Girling calipers on your car. I am speaking from the States point of view. Here the CQ20V NA came with the same brakes and rotors as the S2, just the differnt bolt pattern hubs.
            Greg W.
            • Stick Insect
              • Dec 2003
              • 2338
              IIRC the 20v are the same but the 10v have different calipers ( single pot sliding caliper) There is a different offset between the coupe and the saloon I believe but I have not seen it.
              David
