Using a set of forged front control arms in back?
  • panzerwagen
    • 900
    Anybody here do this yet? I thought somebody here mentioned that they had done this mod.
  • A1QSHIP
    • Aug 2004
    • 975
    Hey panzer, I had asked about this a while back and was told that it would not work.
    I think that it will work but the lower ball joint is fastened with three bolts on the forged control arm and only two on the stamped steel control arm. So you would need to use the ball joint for the forged control arm. Also, the locating point of the strut could be in a different location when mounted to the rear strut, i.e. the wheel may set foward/rearward in the wheelhouse.
    Chris
    "Nulla tenaci invia est via"
    • panzerwagen
      • 900
      Chris, Billzcat1 has done it...
      The guy behind the short shift kit apparently has done this mod.
      I'm gonna see if he's got pix.
      • panzerwagen
        • 900
        Chris, just thought of something.....
        could you not have a compensation plate made for the difference in positioning of the strut? Just thinking out loud...
        • 90quattrocoupe
          • Nov 2003
          • 771
          This is a thread going on Audiworld about using stamped front arms on the back of a Type 89 20V sedan. Could be interesting.
          Greg W.
          http://forums.audiworld.com/9080/msgs/296074.phtml
          • caterpillar
            • 2480
            you may change sides...the right must be used on the left side,on the back...and so on...i will check the P/N.... it can be done i think....
            • A1QSHIP
              • Aug 2004
              • 975
              Just viewing the underside and taking measurements it appears do-able. Not much time to spend on the project with all the training required of the new job.
              Chris
              Oh I almost forgot, I swapped the front control arms right to left to increase the caster angle in the front suspension. I went from about 2.0 degrees to 5.5 degrees caster. The front end "stuck" better in the corners but the tires (205/60/15) rubbed the inner wheelhouse liners. This condition would be exacerbated with wider tires and wheels.
