Okay, today was the time for my Powerflex update. Turned out a lot more difficult than I had dreamed..
Front and rear roll bar - No problem!
Front wishbone - Easy to get off. Hell to remove the bushes, but that was no surprise. Too bad I'd ordered the wrong bushes..
New ones on their way.
Rear lower wishbone - Hmmmm... Bolts are easy to get out, but... Is there really no way to remove the wishbone without the brakeline? Do I need to spill brakefluid to change bushes? That just seems stupid to me..
It's also connected to the handbrakewire with a loop of some sort, seems I just have to cut it off..
Rear upper wishbone - This one I just can't understand. The outer bolt is easy. So is the inner one, until I try to remove it. It's just too long, I can't remove it because it's hitting the fenders. I just sat there looking at it for half an hour because I could not believe it. Will I really have to remove the entire suspension to get this single bolt out?
New ones on their way.Rear lower wishbone - Hmmmm... Bolts are easy to get out, but... Is there really no way to remove the wishbone without the brakeline? Do I need to spill brakefluid to change bushes? That just seems stupid to me..
It's also connected to the handbrakewire with a loop of some sort, seems I just have to cut it off..Rear upper wishbone - This one I just can't understand. The outer bolt is easy. So is the inner one, until I try to remove it. It's just too long, I can't remove it because it's hitting the fenders. I just sat there looking at it for half an hour because I could not believe it. Will I really have to remove the entire suspension to get this single bolt out?
