drag race
  • palles2
    • 133
    drag race
    anyone using there s2 coupe fro drag race??
    i have a s2 coupe 1991 with 605 hk/774 nm.
    i just broke the gearbox 3. time drove it.
    now i got a rs2 gearbox on.
    other thíngs i would have too change???
    402 m 10,99 on street tires.
    659 BHP - 858 nm. 2,6 ccm with 10 x rs2 injectors
    garret gt35r turbo with 1.06 hotside
    2,5 bars of boost :mischeif:
    I would fit some special underpants if I had that sort of torque output.
    Seriously though - the RS2 gearbox should bolt on OK... I can't think of any obvious changes unless a different propshaft is required due to different gearbox length.
    However, something to think about is that the lockable nature of the older 016 gearbox (from UR quattro) is very useful on the drag strip. You'll need to match up the F/D ratio with your front and rear differentials.
    S2 and RS2 are 4.11:1
    Some UR are 3.89:1
    Paul
    • palles2
      • 133
      what about drivetrain???
