Driveshaft Bolts.
  • Azman
    • 3205
    Driveshaft Bolts.
    Guys
    I am changing the Hubs on my CQ20V.
    The list of things I have so far is
    RS4 wheels ET 35 with 225/40/18
    Hubs (if they arrive today)
    Front Disc (zimmerman Drilled)
    Rear Disc (Brembo)
    Front RS2 Calipers, cleaned up and painted Red
    Front Pads
    Rear Pads
    16 x Wheel Bolts Radial seat (Audi fitment)
    4 x Locking wheel Bolts
    I know that I need driveshaft bolts. Are the S2 ones the same as the CQ20 as I have been told this by Audi that they are????????? WAB thinks they are bigger on the S2
    Can anyone confirm this. I want to get the lot done tommorow so need to make sure that I have all the parts.
    Cheers Dudes
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • S2 Ant
    • 3682
    I'll look them up now on the family album and confirm if i can
    Ant
    2011 Kawasaki Z1000
    • S2 Ant
      • 3682
      The inner bolts show as M8x48 for 7A, 3B etc but doesnt list ABY and i cant find it on a different page.
      Ant
      2011 Kawasaki Z1000
      • S2 Ant
        • 3682
        The single big outer bolt is listed in 2 different sizes but doesnt give which model is for which.
        M14x1, 5x73
        M16x1, 5x77
        Is that any help?
        Ant
        2011 Kawasaki Z1000
        • Azman
          • 3205
          I know the fronts are larger than the rears. Good thing is I am getting 3B hubs from a Jreg S2 so hopefully will be the same, especially as the bearing kits are the same item number at GSF. Fingers crossed only time and an undrivable car will tell.
          Cheers Dude
          Dark Grey Avant
          RS2 FARB
          • Azman
            • 3205
            Just had confirmation of the Hubs. Will be arriving today before 5pm.
            Getting closer.
            Just need my braided brake lines to turn up now to finish the whole package off in one go (cos the top mounts are being done at the same time.
            Dark Grey Avant
            RS2 FARB
            • Azman
              • 3205
              Oh heres one. If the bearings have not been removed from the hub, can I still use them?????????
              Dark Grey Avant
              RS2 FARB
              • WabTheKing
                • May 2004
                • 2567
                no,
                you have the hub housing which has the bearing inside,
                on each side of this is a circlip,
                when putting a new bearing in you press it into the hub housing upto the circlip,
                flick the other circlip in, (sometimes there is only one and the bearing pushes upto a face)
                then supporting the inner race you press the hub into the bearing,
                to disassemble you have to knock the inner race out of the bearing. - this usually ****s the bearing
                so unless the hubs come with the hub housing then no you cant use them
                regards
                will (WAB)
                • Azman
                  • 3205
                  Och, something else to add to the list, I will have a look when they arrive.
                  Bummer
                  Will
                  Dark Grey Avant
                  RS2 FARB
                  • mcandmar
                    • Apr 2004
                    • 5118
                    oops, ignore
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                    • Ski
                      • 2591
                      Hi.
                      Sorry for thread hijack... what can I say Jamo is a bad influance...
                      I need some parts replacing, but i dont know their name.
                      Its the driveshaft from the wheel, to the diff, including the 2 CV joins connected to this driveshaft. I need this on the front and back. 4 driveshafts in total and 8 cv joins.
                      I was told I can get a complete unit (4 units) with the CV joins on them, and ... I was told they can be from a A4 which would be cheaper, is this true?
                      ABY Coupe
                      • 90quattrocoupe
                        • Nov 2003
                        • 771
                        Originally posted by Azman
                        Guys
                        Cheers Dudes
                        When I changed out the hub carriers, I just used the same size bolts for the axles, that came on a coupe. New bolts, but same size. No problems.
                        Not all the hub carriers have circlips, so if it doesn't have them don't worry about. Neither my coupe nor the ABY hub carriers, I put on had circlips. Depends on the build date.
                        If you do have circlips, be careful when you insert the new bearing. You just want to snug up to the circlip, if you force it too much you can distort the circlip.
                        Greg W.
