i wonder what is the differences (if there are any) between s2 (aby) and s4 (2,2t, my94) rear differential? etka numbers are not the same...... there is also diff locking, AFAIK s2 has manual ones but s4 has avtomatic locks. is it possible to use some s4 diff parts for s2 diff?
thanks a lot
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
the rear diff vill NOT fit,without heavy rebuillt in the back....if you want thorsen in the rear end,use the thorsen from audi v8 from 89-93.it will fit right in.sutch in this forum,and you wil find the solution,im sure
