Thanks for that info. Sounds better than the AAN dual mass flywheel. I'll get to work removing the dual mass and go 7A for now. I am still tryng to find an aluminium one. Are these as hard to get hold of as it seems?
Dual mass or aluminium flywheel?
Did you change the front pulley or keep the ABY pulley?Originally posted by s2avantI don't subscribe to the bottom end needs rebalancing theory and it's an age old discussion that I'm not gettting back into.
I've had the flywheel in since mid December last year and it hasn't fallen apart yet.
BenGreg
7A is 11Kg or 24lbs less 4.5Kg (10lbs) equals a new total weigh of 6.5 kg or 14lbs.
Aelred, who did the machining for you? What is your advise on the rebalancing of the engine?Comment
