WHOLE DRIVESHAFT when the center bearing goes? Why do they not just suggest to replace just the bearing?
I don't understand the logic of it? What is their logic for this expensive & totally uneccesary
replacement?
centre bearing (Febi/Bilstein Part Nº 05196) and the CV joints (Löbro (OEM) CV-joint Part Nº 301142/Porsche Part Nº 923 332 032 00)
Febi 05196 is BMW GSF part number B51050 approx £13 plus VAT
CV joint is GSF part number P43828 approx £40 each plus VAT
Now that is a top reply!
Go on be honest, how long????
The Perfectionist
just for the record the bmw centre bearing is not exactly the same as the audi one, from memory it has a differnt compound rubber,(could be wrong on what is differnt so dont shoot me) if you get your prop shaft overhauld by a "propper" no pun intended prop shaft person they wont recomend using the bmw one,
not saying it wont work, or that the sun with die if you do, only relaying what i was advised
you know like with atmospheric dump valves/ looped out wgfv's/ boost controllers etc.
The BMW bearing option has been used loads of times, i remember the audi dealer i used to work for using one on typ 85 90 q saloon, no prizes for guessing who told them it was possible
