1st to 2nd crutch (Fixed)
  • ian_jemo
    • Aug 2004
    • 284
    Since I have owned the car I have always got a gear crutch when changing from 1st to 2nd.
    But since my incident with me putting to much oil in my car and no gearbox oil at all, and driving it. The problem has now gone away. (WARNING I'm not recommending anyone to drive with no gearbox oil!!)
    If anyone has got the same problem I would recommend changing the gearbox oil it might solve the problem. And when the car has no gearbox oil in it, it might be worth putting it into all the gears a few times to knock off any bits which have built up.
    I don't get any crutch now, at all not even at redline in 1st gear.
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
  • iain1067
    • 984
    Yet more proof that despite audi saying that gearbox and diff are filled for life, they clearly do benefit from an oil change. BTDT on every quattro i have ever owned and always noticed a big difference
    Iain
    • ian_jemo
      • Aug 2004
      • 284
      I can't believe the difference, I put some rubbish halfords gearbox oil in it as well.
      • Ski
        • 2591
        at 200k I descided to top up my gear box oil.
        To my suprise it swallowed a whole bottle, and ever since then, my whole centre console gets hot after driving it for half hour (gear knob etc.. get hot).
        the only conclusion i can come up with is that the hot oil it flowing higher up in the gearbox than before.
        ABY Coupe
        • iain1067
          • 984
          Ski, what sort of oil did you put in?? doesn't sound right to me that it should get that hot after only 30 minutes??
          Iain
          • Chris5044
            • Feb 2005
            • 1663
            yep ... thats how my gearbox went!!!!! lack of oil!!! ... the gearbox didnt just give up either it still ran but not sounding good ... (audis good point -- strength)
            bad point ---- assuming too much
            • iain1067
              • 984
              Quite possibly one of the most overlooked things on the list of things to do, along with greasing the centre bearing on the propshaft. and it is a long list with anything quattro!!!
              Iain
