Is this an S2 3B flywheel?
  • mcandmar
    • Apr 2004
    • 5118
    I think i'm missing a timing pin on the back side of the flywheel, can anybody confirm?
    Thanks,
    Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • mcandmar
    • Apr 2004
    • 5118
    Front side..
    • ~Delta
      • Apr 2005
      • 797
      Looks like either a 3B or 7A item, top picture seems to show the remains of the firing pin...
      Never show a fool a half built house.
      Never underestimate the power of stupid people in large groups.
      Life is like a **** sandwich
      The more bread you have, the less **** you eat
      • mcandmar
        • Apr 2004
        • 5118
        Ok so is the bottom right where the pin should be? Any idea on how long it needs to be?
        Cheers,
        Mark.
        • martinjs
          • 3205
          According to the manual, when the flywheel is fitted you have to fit the firing point sender (G4) to the bell housing, rotate the flywheel so the pin points to the sender the gap should be 0.45-1.25mm between end of pin and the sensor.
          HTH
          • ~Delta
            • Apr 2005
            • 797
            Aye, bottom right of top picture. Length approx. 10mm, but length isn't really critical, distance of pin to TDC sensor once flywheel is bolted to crank however is.
            • mcandmar
              • Apr 2004
              • 5118
              Perfect thanks guys
