question about diffs
  • s2_southwest
    • Oct 2004
    • 823
    Is the 1990 COUPE 2.3 10V the same as the S2 diff? i should imagine that they are all the same.
    cheers
    Matt
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
    IIRC it's not ask MartinJS
    • 90quattrocoupe
      • Nov 2003
      • 771
      cheers
      Matt
      The only differences is the flanges. Your 10v has either 90mm or 100 flanges and the S2 has 108mm flanges.
      Greg W.
      • caterpillar
        • 2480
        nope. the housing arent the same ether. but the same cron and pinjon....and same ratio 4,111
        • Henka
          • 585
          • Home: Sweden
          What? Even the rear diff of my Audi 80 Quattro was the same as the S2 Coupe. Caterpillar - you must mean the S2 Sedan/Avant - that one's got a snout on it so it's not the same. Older coupe's had the mounts integrated in the housing but this coupe shouldn't have that - so the housings should be the same.
          • caterpillar
            • 2480
            was that i ment.....
            • porkkis
              • 1994
              Greg is right. The only difference is the flanges and you can swap those.
              All 5 cyl t89q cars have the 4.11 diffs and only difference is the mentioned one.
                I can verify this - saw it when martinjs swapped his S2 rear diff for one from a CQ20V - internals are the same. Only difference is the driveshaft flanges which can be easily transferred.
                • prosty
                  • Jun 2005
                  • 1114
                  Borrowing this thread: Which diff fits the S2 avant? Other than RS2 and the stock of course?
                  2004 9-5 aero
                  2009 Subaru Legacy Diesel
                  1994 Toyota Supra Eurospec 6-spd LHD
                  3-4 Audis in parts
                  • caterpillar
                    • 2480
                    like the audi 80 Q pre 93 are the same as rs2 ones... the really long ones, varning 3 different ratios.
                    • prosty
                      • Jun 2005
                      • 1114
                      Okay so the 80Q before 93 with 4.11 ratio will fit? Do they have diff-lock or do I just switch the internals?
                      2004 9-5 aero
                      3-4 Audis in parts
                      • caterpillar
                        • 2480
                        what car have you?? before 93 or is it a sedan?
                        • prosty
                          • Jun 2005
                          • 1114
                          95 s2 avant
                          2004 9-5 aero
                          3-4 Audis in parts
                          • caterpillar
                            • 2480
                            then you have a really long unit(1meter housing)
                            • prosty
                              • Jun 2005
                              • 1114
                              Yes. That's why I wonder which one fits
                              2004 9-5 aero
                              3-4 Audis in parts
