Strange whine from 80 Quattro..
  • Coxy
    • Jun 2005
    • 1090
    ....and no, it's not the wife!!
    It's a speed related whine as opposed to engine or gearbox related.
    The whine get's higher pitched at faster speeds. Only really notice it about say 40-50 mph.
    If I "coast" then the noise is still there relative to speed.
    Hard to tell where it's coming from, presume driveshaft??
    any ideas???
  • AAH!
    • 497
    • Home: United Kingdom Current: Bhutan
    Wheel bearing?
    formally RS2 +
    • Coxy
      • Jun 2005
      • 1090
      Could be???
      Can't really work out where it's coming from tbh apart from the front of the car.
      Any easy way of checking it whilst stationary other than getting the missus to drive and hanging me head out of each window????????????!!!!
      • volcano rs
        • Jun 2005
        • 2265
        jack up the car from front grab your wheel top and bottom and feel for play
        • AAH!
          • 497
          when driving at a constant speed with the car whining, try steering to the left and right and see if the noise increases and decreases. This could indicate a dodgy wheel bearing.
          Could also be the brakes pads rubbing.
          formally RS2 +
          • porkkis
            • 1994
            Could also be the gear box. Front diff pinion bearing is quite common fault in 012 and 01A series boxes.
            Luckily whine would more probably be a wheel bearing. I'd say the usual GB noise is rustling or rattle or something between those. Hard to explain in english
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              I have a sort of rattle that turns into a whine at higher speeds. Front diff bearing I think. It sound worse when accelerating on decelerating. You can hear it coming from the gearbox. A worn wheel bearing sounds like it's coming from the.. err.. wheel.
              SS
              • Coxy
                • Jun 2005
                • 1090
                OK, front of car now in bits.
                n/s wheel bearing is fine. Shocker is gone and the arm. The drive shaft sounds notchy when turning it. I presume the extra vibration from driving the car with a knackered shocker has mullered the diff bearing.
                Is it possible to change the diff bearings with the box in?
                Also, does the S2 box fit in a 2.6 V6 Quattro as there's on on eBay at the moment if needed?
                http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
                • ~Delta
                  • Apr 2005
                  • 797
                  S2 box will fit Coxy, but 5 cylinder ratios are different to V6. Final drive for S2 and all 5 cylinder B3 / B4 quattros are 4.11:1, V6 quattros are 3.89:1.
                  Fitting a 5 cylinder box will mean your rear differential will need replacing as well.
                  Never show a fool a half built house.
                  Never underestimate the power of stupid people in large groups.
                  Life is like a **** sandwich
                  The more bread you have, the less **** you eat
                  • Stick Insect
                    • Dec 2003
                    • 2338
                    Coxy, it will be the pinion bearings. as commented up the thread they are a common problem.
                    I know
                    David
                    • Coxy
                      • Jun 2005
                      • 1090
                      That was my fear!!!
                      can I confirm it is a gearbox out job for this?
                      My mechanic fears it is!!!
                      • Ice
                        • Jan 2005
                        • 24
                        Front diff pinion bearing - whats the partnumber?
                        Car is a B4 -92 NG Q.
                        Audi B4 TQ equipped with AAN and other nice parts
