Another DSY gearbox
  • Sweeper
    • 1317
    • Country: Latvia
    Another DSY gearbox
    question
    Well i have the rs2 linkage and the DSY(without oil pump) gearbox.
    How in the world can i fit it in the 3B ?
    I understand that i need to shorten the propshaft for about 2-2.5cm ,ok fine. But what to do with the mouting brackets ? I don't have any that fit this box and the subframe :/ , even if i will fit a spacers to subframe.
    Anyone can help ?
    Vadim.
    New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
  • markrs2
    • 185
    You need the subframe and mounts from a sixspeed car (subframe can also come from a v6)
    • Sweeper
      • 1317
      • Country: Latvia
      B4 V6 coupe ?
      Vadim.
      • markrs2
        • 185
        Originally posted by Sweeper
        B4 V6 coupe ?
        yes
        • Sweeper
          • 1317
          • Country: Latvia
          mark: Will the original DSY or EDU brakets fit this subframe positions ? Or i need ANY 6speed brakets :> ?
          Vadim.
          • markrs2
            • 185
            No you need the supports from a 6 speed 80/90/coupe. Part numbers are:
            8A0 399 113 E
            8A0 399 114 E
            • Sweeper
              • 1317
              • Country: Latvia
              mark: Thanks
              And as I've understand there are no alternatives , only S2/RS2 ABY/ADU had these supports ? No other cars ? As it's kind of hard to find a second one parts for ABY/ADU , only 3B from where i live
              P.S.
              Will original DSY support braket do , if i find any ?
              Vadim.
              • markrs2
                • 185
                mark: Thanks
                P.S.
                I'm afraid so. The DSY support brackets are too tall to use with this subframe and sit too far back/forward (can't quite remember). You can modify the subframe to take the DSY supports but S4's/RS4's etc that use these supports tend to have a lot of transmission movement and require additional stabilisers. I can't be sure but my thinking is that the tall supports do not support the box as securely as the shallower S2/RS2 parts and allow too much movement of the box.
                • ~Delta
                  • Apr 2005
                  • 797
                  B4 V6 coupe ?
                  B4 V6 Coupe with automatic transmission...
                  Never show a fool a half built house.
                  Never underestimate the power of stupid people in large groups.
                  Life is like a **** sandwich
                  The more bread you have, the less **** you eat
                  • Sweeper
                    • 1317
                    • Country: Latvia
                    ~Delta: Manual wo't do ? And it doesn't matter is it 2.6 or 2.8 ?
                    Vadim.
                    • Sweeper
                      • 1317
                      • Country: Latvia
                      Mark I've bought the both supports.
                      114 E fit like a perfectly.
                      113 E doesn't fit at all :/ , it has 3 holes for bolts and the gearbox have 4. + it have free space when you mount it(a gap).
                      Btw they were 240GBP for two
                      Any ideas anyone ?
                      8A0 399 113 E
                      8A0 399 114 E
                      Vadim.
