Gearbox Removal
  • Albie S2
    • Oct 2004
    • 138
    • Country: South Africa
    Gearbox Removal
    I would like to know if there is any special way of removing the gearbox of the s2 3b 91 model because i cant get the box out all the neccesary brackets and propshaft and cv's and steering damper are removed box will slide approx 8cm out but refuse to go any further and is stuck what could possibly be wrong because i am really battling here
    thks chris
    sa
    www.cardomin.com/member/745893
  • NoNonsense
    Forum Sponsor
    • Apr 2004
    • 673
    thks chris
    sa
    i cannot comment on S.African models, however, american cars had what is called ProCon10 which has metal cables that loop around the top of the gearbox....perhaps that hasn't been undone yet and it is holding the case in place. Otherwise, have you disconnected the shift linkage?
    Joe "NoNonsense"
    axis motorsport
    joe@axismotorsport.com
    "At the end of the game, the king and the pawn go back in the same box."
    • Albie S2
      • Oct 2004
      • 138
      Gearbox Removal
      yes i did remove all the pro-con cables and the gear-link is it possible for the input shaft to twist and that it wont be able to pull trough the clutch plate because i did some heavy launching with it
      thks chris
      • CHEN
        • 329
        Have you tried removing the front snubber bracket and tilting the engine slightly to get a better angle, also removing the track rods at the strut end normally helps
        • NoNonsense
          Forum Sponsor
          • Apr 2004
          • 673
          thks chris
          chris,
          since you have done all of that already, then my next best guess is that you simply need to wiggle (read: shake the tranny like hell) to get it out. the input shaft will indeed be a little stuck to the splines on the clutch disk and usually some good shakes will release the two. i don't think your hard launches or anything will affect this process. good luck!
          Joe "NoNonsense"
          axis motorsport
          • prosty
            • Jun 2005
            • 1114
            You could loosen the engine mounts to lower the engine, try lifting the engine a bit, or just wiggle, this is when I come in handy @ our garage.
            2004 9-5 aero
            2009 Subaru Legacy Diesel
            1994 Toyota Supra Eurospec 6-spd LHD
            3-4 Audis in parts
            • Albie S2
              • Oct 2004
              • 138
              Gearbob removal
              i cant believe this thing is so stuck i shake it so hard the car almost fell of the tressels it standing on, in my live i did many gearboxes in and out but this one is another story
              • prosty
                • Jun 2005
                • 1114
                Have you loosen all the cables to it (speed-o) and so on? Try lowering the engine, sometimes the back of the tranny touches the steeringdamper. Try loosening those bolts and push it aside.
                /Markus
                2004 9-5 aero
                3-4 Audis in parts
