sourcing RS2 clutch kit
  • veneto rs2
    • Jun 2006
    • 1022
    • Country: Veneto
    Ciao all
    Seems the ADU/ABY clutch kit from sachs #3000951729 it's no longer available
    Any of you guys knows an alternative that's available to buy from other brands (Luk/Valeo etc etc)?
    Thanks in advance!
    Stefano
    http://www.audisportclub.com/
  • A80Avant
    • 10873
    • Country: Greece
    Southbend from the USA through Marc Swanson (efiexpress) . That's what I have been using without faults
    • saltinot
      • May 2004
      • 1946
      The kit isn't available, but maybe the individual parts are still available separately?
      • ralleyquattro
        • Oct 2007
        • 536
        • Home: Poland Current: Canada
        From what I have seen the clutch pressure plate and friction disc are same size as 7A (hence the spacer with DM flywheel). You can either go 7A (uprated) and 7A flywheel and ditch the spacer, or just get a 7A uprated clutch kit. People, correct me if I am wrong.
        www.quattro.ca
        B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
        B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
          Martin: As far as I know, the 7A flywheel is quite flat and uses a 034141117BX clutch pressure plate. The ABY and ADU and the ABH (4.2L V8) all use a dog dish flywheel and, as a result, the 077141117L clutch pressure plate is quite different (flatter). I know this from personal experience with Marc S. from EFI Express sending me a 7A pressure plate when my V8 clutch failed.
          Dog dish style flywheel (this one has been machined for VEMS):
          Photo courtesy of Islingtonaudi (Doug W.)
          ABY Flywheel and clutch photo courtesy of IrishS2 (Eric)
          • saltinot
            • May 2004
            • 1946
            From my old Sachs catalog......RS2/S2 (ABY) part numbers.
            This gallery has 1 photos.
            • Canadian RS2
              • Oct 2009
              • 145
              I did a fair bit of research a couple of years ago when I replaced the clutch in my RS2. Through advice from Marc Swanson I ended up going with a 7A kit from Southbend along with a resurfaced 7A single mass flywheel. The dual mass RS2 flywheel was very hard to find and expensive as it is specific to the RS2 as Dave mentioned. Using the 7A required the removal of the spacer between the engine and the transmission as well as some shorter bolts to attach the transmission to the engine block.
              There are some very light aluminum 7A flywheels out there but I went with a resurfaced OEM flywheel as it is still lighter than the RS2 one and maintains the most of the smoothness of the DM. Some people have noticed chattering at low RPM's but I really haven't experienced any negative driving characteristics. The lighter flywheel makes for quicker revs but not night and day differences. I'm happy with the change.
              • ralleyquattro
                • Oct 2007
                • 536
                Did you have an issue with your RS2 flywheel?
                www.quattro.ca
                • Canadian RS2
                  • Oct 2009
                  • 145
                  A loose input sleave bolt that was wedged behind my pressure plate decided to escape through the wall of my transmission. The clutch and flywheel were coated in tranny fluid. I could not find anyone that would refinish a DM flywheel so I decided to go with the SM at that point.
                  Untitled by Dave ten Broek, on Flickr
                  • ralleyquattro
                    • Oct 2007
                    • 536
                    Ouch!
                    www.quattro.ca
                    • veneto rs2
                      • Jun 2006
                      • 1022
                      • Country: Veneto
                      Thanks guys for your replies!
                      We want to go in as original as possible.
                      I'll keep you upadted on the result, the RS2 it's not mine but finding a solution will be good for me and for every RS2 owner anyway, soon or later...
