Auto Trans Faults Codes
  • GarCo20
    • Nov 2016
    • 48
    • Home: Puerto Rico Current: Germany
    Hello,
    I have a 1993 Audi b4 80 with 2.3e and auto trans. The trans stays in 1st gear and will not shift into a high gear. The VAG-COM scan gives me the following codes:
    Address 02: Auto Trans Labels: None
    Part No: 097 927 731 CJ
    Component: AG4 Getriebe 097 1265
    Coding: 00000
    2 Faults Found:
    34-10 - No Elaboration Available - Intermittent
    00652 - Gear Monitoring
    27-10 - Implausible Signal - Intermittent
    Could somebody please tell me where these components are and what to do with them. Also, if there is anything else I need to know to troubleshoot this my car.
    Thanks for your support!
  • Dynasty
    • Jan 2015
    • 79
    • Country: Norway
    Maybe this info can help you: http://wiki.ross-tech.com/wiki/index.php/00652 Personally i would have checked the Multi-Function Switch (F125?) first (located on the gearbox).
    • GarCo20
      • Nov 2016
      • 48
      Thank you for your prompt reply I really appreciate it. Also, I wonder is you know the part number of the multi-function switch?
      Thanks for your help,
      • Dynasty
        • Jan 2015
        • 79
        • Country: Norway
        Take a look at this site: https://nemiga.com/cat_spares/etka/audi/a80/114/927500/
        If your gearbox is a AAZ, then it is part number 13 in the link above.
        • ChrisAudi80
          • Oct 2011
          • 236
          • Home: Norway Current: Thailand
          Did you check if the trans has enough oil?
          '96 UrS6 auto PRJ chipped E85
          '95 80Q AEB VEMS E85
          • GarCo20
            • Nov 2016
            • 48
            Thank you very much for the information Dynasty.
            • GarCo20
              • Nov 2016
              • 48
              The oil Level is good. Also, I changed the oil and filter. Thanks for the support!
              • GarCo20
                • Nov 2016
                • 48
                Dynasty,
                I ordered the multi-function switch. My transmission have the part number: 095919823B. Once I received the part, I will let you know if it fixes my issue. Thanks for your support!
                GC
                • GarCo20
                  • Nov 2016
                  • 48
                  Dynasty,
                  My automatic transmission went bad; So decided to replace with a manual transmission. Thanks for your help!
                  • popdemonic
                    • Dec 2007
                    • 1304
                    • Country: Thailand
                    from my experience once the gear monitoring fault shown,most of the time your gearbox needs overhaul soon.
                    one of a few I5 from Asia.
