OK so the ABY one is £200 from TPS Quattro corner only have 3b in stock what's the options to avid spending £200, can I swap parts from my leaking one into a new 3b to make it ABY
Which clutch master cylinder
Tags: None
You could buy a cheaper one?
https://www.ebay.co.uk/itm/AUDI-S2-B...C~gJ:rk:1:pf:0
Or, overhaul your existing one. Seal kits are available. As long as there is no scoring to the piston, its a good option. Very easy to do, instruction videos on YouTube.
I'm not sure but it sounds like the 3b and ABY have a different shaft diameter so don't think you can swap parts.Nothelle S2 Avant
Urs6 plus project gone -
Urs6 plus project goneComment
You can buy a 3b one - widely available from euro car parts etc.
Then swap over the push rod as the aby has an m8 thread.
Compbrake do them, gone up in price since I did conversion a few years ago:
