Audi Urs6 RWD conversation for dyno test ?
  • Audi Urs6 RWD conversation for dyno test ?
    Hello,
    It’s my first post on S2forum, I’am french (sorry for my English
    Hello,
      No worries
      Project Audi s2 coupé 1996
      http://http://www.s2forum.com/forum/showthread.php?t=80796]
        to the forum fella.
          Thank you for your welcome
            have you already made a rwd convertion for dyno test
              To convert quattro to rwd you need to weld the torsen solid, remove front driveshafts leaving outer CV joints in place to prevent bearings from splitting. If it's just for dyno testing, then removing propshaft and fitting suitable fwd gearbox would be a better option imho.
                hello thank you for your explanation, for you that it is the maximum admissible torque in RWD?
                i have gearbox 6 speeds CBL and Audi v8 rear diff
                  You can YouTube S4 RWD for an example of it being done.
                  You will either need to buy a center diff to weld and temporarily install for the Dyno..... Or as suggested above, Remove the prop shaft and install a FWD transmission for the Dyno...
                  Or the easiest option would be to use a 4WD Dyno??
                  ​​​​​​Jase.
                    I just watched on youtube there are setups of over 800hp! perfect
                      it's complicated where I live for the rental of a dyno..
                      my friends have a dyno but it’s 2 drive wheels dyno
                        I will do the conversion to RWD I will post the photos on the post and dyno test
                          Little picture on my setup:
                          This gallery has 1 photos.
                            Hi
                            after reflection I finally made a convertion to FWD. disassembly of the transmission shaft and locking of the torsen
                            • #15
                              This gallery has 2 photos.
