Howdy folks,
I am after some advice on what other parts to replace when having the gearbox in my ABY coupe replaced (something I’ve been getting around to doing for a while).
The 1st gear is shagged and I have an (apparently) good condition 2nd hand box, also a CGR from an S2.
The work will be by a mechanic in a workshop, ideally with the engine in (per the sticky guide in the transmission section of the forum).
My S2 has done 135k km and as far as know the engine and gearbox has never been out.
The mechanic has recommended at a minimum:
- clutch
- clutch release bearing; and
- slave cylinder
I am also thinking subframe mounts..
What else is worth doing, without replacing everything that doesn’t need to be touched?
Are there any gaskets required for the cats or elsewhere?
- clutch
- slave cylinder
