I have a UrS4 AAN auto swap engine and want to fix a 3B pilot bearing flywheel.
Unfortunately there is a bushing for the torque converter in the crank, how can I remove it?
Thank you in advance!
Chris
I hava made a puller. First you make thread in it. Wind threaded bar into it. Next you bolt thick plate with hole for the bar to the flywheel bolts (with washers), and pull bar with the nut. Comes really easy. If not - check your system. I used old flywheel bolts, because I had new ones waiting.
Sau
