What happens if you launch with the diff lock in? We playing off road the off day in the land rover and i was learning to use the lower and high boxes and the air lockers which lock the diffs indepently
So the general question is what happens? Any videos?
I have often asked this and received mixed replies...for example when I asked about it at the GTi last year, all the other S2's that ran didn't bother using it, so I didn't bother either and was actually very fast off the line (I dropped Gregs beast off the line, but then further down the track, his slight 150 horses advantage wasted me )
I have tried it at my local traffic light GP....a full bore launch in the dry with the diff lock engaged and I have to say that it worked nicely, but you have to wonder how long before you break something.
From my understanding of the mechanics in the rear diff, the locking pin is not that thick, so too many full bore launches might just shear the pin
I guess we need Audiman or someone who has had one apart to comment on how strong it might be.
Cheers n
Si
95 ABY S2 Coupe - Ragusa Green Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey With every option available (except a towball)
I would say its not really designed for this sort of thing and in the dry i can't see it being a massive advantage. Would love someone to prove otherwise though
Ragusa Coupe gone!
you broke the rear shafts???
How on earth did you do that? I never locked the diff or had problems with my drag launches whatsoever. And I did a lot of them. Last year I've been running the Torsen in the back.
RS2 Black - stock 315 HP
RS2 RS blau - stock 315 HP
Sport Quattro - 1005 HP High Octane website
There is no locking pin - there is a big gear-type collar that locks the diff housing to the left side out-put shaft. So, in effect, all the power is transmitted via the spider gears - maybe not the most powerful way to transmit power to the ground. Sure, they will probably hold up just fine - I mean people have been doing the white n' blue mod for years. In the long run it's probably not the best of solutions.
Jeffer's Torsen is probably a better solution but it has the downside of heating oil (Torsens heat the oil alot!) and it's heavier - so it steals power. Still, one must say that the power lost is no biggie compared to the benefit of having LSD (not the drug mind you).
Look at all the Swedish 9s runing cars - Most, if not all, of them run just a locked stock rear axle - some even use a welded up center with no issues. Just yank that wire man!
Oh and - there is a reason that Porsche went with the bigger rear outers on the RS2 (found in the S2 Avant in 93) - the last way longer!!
In my car the big gear "diff lock" was broken when I bought the car. So it is possible to get it in parts. At this moment couldn't find the pictures of it.
The car had only 310hp at that point, but I don't know what the previous owner had done to it.
I've broken the rear diff without the diff lock engaged, and my friends always break their drive shafts when they don't use their diff locks. So I'm a PRO difflocker all the way. 2 wheels is better than one, simple math. ?
2004 9-5 aero
2009 Subaru Legacy Diesel
1994 Toyota Supra Eurospec 6-spd LHD
3-4 Audis in parts
Is there a greater transmission loss when using the diff lock for drag racing? Also i once broke my rear left C/V joint while doing a power takeoff but i was not using the diff lock it probably didnt help and i had passengers at the time.
Reason: spelling
1994 Indigo Blue S2 coupe
1994 80 Avant 1.9 TDI
2005 Yamaha Fazer 1000
1953 AJS Model 18S
