B6 transmission in B4 possible?
  • Avant_quattro
    • Aug 2018
    • 9
    • Country: Spain
    hi guys!
    I'm in a project of rebuilding an Avant Quattro building the body from scratch.
    I currently have it in a FWD configuration awaiting a good donor for the Quattro install.
    I just got a donor 1.8T20vt Quattro A4 B6, and apart from taking advantage of the seats I'm investigating if I can use the whole rear transmission.
    If I get a rear B4 subframe, can I use the differential and driveshaft from the B6, what driveshafts should I use?
    actually use S4 B5 front hubs
    Let's see if someone can help me
    Thanks!
    This gallery has 1 photos.
    • Dec 2017
    • 5984
    It's not an easy swap. You would have to cut and 're weld various points in the chassis. B6 is very different. B5 was the last version that's almost identical to S2 Avant. Even that has quite a few differences, such as hub size.
    • Avant_quattro
      • Aug 2018
      • 9
      • Country: Spain
      Hi guys! I have been evaluating and finally I will sell the B6 and take a B5 quattro as a donor. I will publish updates.
