HI I'm newbies here.I own the 1995 UrS6.Now I'm experiencing some knid of vibration issue when the car is under boost and gone when back in Vacuum.I just removed the propshaft to see the center bearing and F&R Cv joint to check because there was some crunking sound when the is accelerated. And found out the grease on the front CV joint was dried out. So I filled in with the fresh grease both F&R.Amazingly,The crunking sound was gone.The Centre bearing is supposedly to be in a good shape.
I also replaced the left front control arm and seem that this will help the vibration issue. the vibration is still there but lesser.Everytime when the car is under the boost,the vibration will come out through the steering wheel and the car has a bit vibration also. I have 2 sets of Rims one is stock 16" Avus and another is 19" w.work rims. the rims is proper balanced. The suspension was renewed a few thousand miles ago. one thing right here is the Rotor disc is bent because everytime
when i apply the brake the steering wheel will shake but.I'm really don't know if it will be related to this vibration.So now I'm really don't where to begin to diagnose this.
the wheel bearing is still stock it has never been replaced.Please shared me your guess.
POP
POP
the symthom was coming on when the car is underboost or hard accelerated and off when I let off the gas.There's slightly vibration through out the car but be obvious on the steering wheel.
